Date/Time: Fri, 06 Nov 2026 08:05:24 +0000
help getting futures data
View Count: 829
| [2021-10-06 02:39:35] |
| User751124 - Posts: 3 |
Hello there I need help to have the CME data in my account now I have a positive balance of services but I don't understand the steps to follow to obtain a depth of market package with CME data Thanks |
| [2021-10-06 14:33:46] |
| John - SC Support - Posts: 48449 |
Just follow the steps outlined at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* And when you activate the exchange(s) you want, make sure you select the ones that specify that they have Market Depth, otherwise, you will not get the market depth data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
