Date/Time: Sun, 19 May 2024 22:11:02 +0000
Daily Currency Futures Charts
View Count: 2047
[2013-04-23 18:17:19] |
User23815 - Posts: 209 |
New User. Using Interactive Broker futures feed. I use intraday charts to trade but also have daily historical charts in a chartbook as well. When the daily charts try to bring in historical data, the current day shows, then the next day or two does not (SC lists an error in the log)and then prior days seem fine again. Am I supposed to be using a continuous chart or SC data for those? Help please. Thanks
[2013-04-23 20:10:26] |
What is the symbol of the chart? Go to Edit >> Delete All Data and Download to re-download the data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-29 12:47:52] |
This solution worked when I received the reply. I had tried it before and it didn't. Now after the weekend, the same issue is occurring. The solution doesn't work and I get a Download Failed message. These are Interactive Broker feed, currency futures daily historical contracts. Correct up through last Thursday. Friday doesn't load. Today does. Symbols are EUR, GBP, JPY all 201306, and GLOBEX.
[2013-04-29 16:43:01] |
When you select Edit >> Delete All Data and Download for a Historical Daily chart and get an error, then post a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
