Date/Time: Tue, 15 Jul 2025 17:17:12 +0000
How do I comment out alert code to use later?
View Count: 1501
[2014-03-26 14:41:46] |
MonteCarlo64 - Posts: 23 |
If I cannot comment out the alert code below using { } or // then how do I do it? =or(ID3.SG4 <= 32000,ID3.SG4>=35000) |
[2014-03-26 15:29:05] |
You can AND in a comparison that is obviously false. Therefore, your example will look like this: =AND(0,OR(ID3.SG4 <= 32000,ID3.SG4>=35000)) Sierra Chart Support Date Time Of Last Edit: 2014-03-26 18:09:00
[2014-03-26 17:50:13] |
You did not answer the question. Which is: How do I comment out ANY code that I want to leave in the alert condition but NOT use (make it ignorable) while using another line of code?
[2014-03-26 18:09:17] |
This is not supported.
