Date/Time: Sat, 18 May 2024 16:14:19 +0000
SPREADSHEET real time ISSUE
View Count: 412
[2021-09-30 13:56:59] |
User278398 - Posts: 291 |
hello, after i try to open my spreadsheet which i saved, "it doesn't work" what i need to do, to connect it to real time and to his chart ? (when i open a new spreadsheet it works correctly) thank you. |
spreds.jpg / V - Attached On 2021-09-30 13:56:43 UTC - Size: 195.55 KB - 135 views |
[2021-10-11 23:25:09] |
There needs to be a Spreadsheet Study on the chart linked to that particular Spreadsheet.: Spreadsheet Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-11 23:25:42
