Date/Time: Wed, 01 May 2024 08:10:07 +0000
Numbers Bar don't drawing
View Count: 1110
[2014-03-26 11:36:51] |
sts - Posts: 9 |
Indicator "Numbers bar" don't drowing a cells |
sierchart_01.png / V - Attached On 2014-03-26 11:36:27 UTC - Size: 85.51 KB - 346 views |
[2014-03-26 16:47:17] |
It is not clear to us how you have configured the Numbers Bars on that chart. Also you need to use the new CTS T4 symbol format as explained here: Notice: CTS Trading Service Symbols | Post: 27451 Change the symbol of all of the charts to the new format. You need to use: 6E.20140600.CME_Fo If there still is a problem, then open a new chart and apply the Numbers Bars study without any changes and provide an image of the chart by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-26 16:47:46
[2014-03-27 06:25:23] |
sts - Posts: 9 |
Hi, I don't change and using initial settings of numbers bar. About 20.03.14 all was fine but now it's just don't drawing anything.
sierra_02.png / V - Attached On 2014-03-27 06:25:05 UTC - Size: 60.58 KB - 318 views |
[2014-03-27 06:32:07] |
sts - Posts: 9 |
I'm sorry, I just hasn't package 5, but I thought that I has.
[2014-03-27 07:58:17] |
You are already on package 5 and that is not the problem. Change the symbols of the charts using the new format. This is explained here: Notice: CTS Trading Service Symbols | Post: 27451 After you do that, reconnect by selecting File >> Disconnect and then File >> Connect to Data Feed. Not quite sure this is the problem. Let us know if it solves the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-27 07:59:25
