Date/Time: Thu, 02 May 2024 05:53:14 +0000
Your program does not close open positions
View Count: 1346
[2014-03-26 10:21:25] |
User81946 - Posts: 9 |
Your program does not close open positions. To work not probably. Order And Positions does not correspond to real open positions at a stock exchange! (Ваша программа не закрывает открытые позиции. Работать не возможно. Order And Positions не соответствует реальным открытым позициям на бирже!) Trade Order Error: Unable to modify order because it is no longer working. Internal Order ID: 2224 | 2014-03-26 11:09:11 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2283. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 12:52:44 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2284. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:25:54 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2285. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:26:09 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2286. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:26:12 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2287. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:26:14 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2288. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:26:16 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2289. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:26:18 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2290. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:26:19 CTS FIX: Received LastRptRequested in execution report for account: M4835. Inserting missing order fills. | 2014-03-26 13:38:21 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2291. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:38:28 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2292. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:50:56 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2293. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:51:46 Trade Order Error - Order error: Unable to submit order without security definition. Internal Order ID: 2294. Service Order ID: (none). Symbol: 6E.20140600.CME_Fo | 2014-03-26 13:59:33 |
[2014-03-26 10:36:36] |
The fault with this lies with the CTS T4 system and how it works relating to symbols. Update Sierra Chart to 1111 or higher by selecting Help >> Download Prerelease. See if that resolves the problem. For help with the Trade Position problem, make sure you are using the correct symbols in the Chart and trade DOM windows. Refer to: Notice: CTS Trading Service Symbols | Post: 27451 And refer to help topic 80 here: http://www.sierrachart.com/index.php?l=doc/helpdetails80.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-26 10:37:09
[2014-03-27 08:15:04] |
All your instructions has executed. Yesterday all worked normally. Today 6E, TF obtain only the historical data. ES obtains the historical and real data. Help please |
[2014-03-27 08:59:52] |
We see you are still running Sierra Chart version 1110. Update Sierra Chart to 1111 or higher by selecting Help >> Download Prerelease. See if that resolves the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-27 09:00:24
[2014-03-27 09:43:05] |
Sierra Chart 1112 6E.20140600.CME_Fo Does not work. 6E.CME_20140600_6EM4.CME_Fo Works Help please |
[2014-03-27 09:45:19] |
Provide a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-27 10:38:07] |
Software version: 1112 | 2014-03-27 13:58:15 Usage end date: 2014-10-25 | 2014-03-27 13:58:15 Enabled for: Sierra Chart Historical Data Service. | 2014-03-27 13:58:15 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-27 13:58:15 Active service: CTS T4 | 2014-03-27 13:58:15 Time Zone: +04:00:00 (MSK+04) | 2014-03-27 13:58:15 2014-03-27 13:58:15 Local computer clock time | 2014-03-27 13:58:15 2014-03-27 09:58:15 GMT time | 2014-03-27 13:58:15 2014-03-27 13:58:15 Time zone adjusted time | 2014-03-27 13:58:15 Time difference to server time: 0 seconds. | 2014-03-27 13:58:15 Program path: C:\SierraChart\ | 2014-03-27 13:58:15 Data Files path: C:\SierraChart\Data\ | 2014-03-27 13:58:15 OS Version Number: 6.1 | 2014-03-27 13:58:15 Checking for new symbol settings for cts | 2014-03-27 13:58:15 Symbol settings are up-to-date for cts | 2014-03-27 13:58:16 6E.CME_20140600_6EM4.CME_Fo [CB] #1: Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2014-03-27 13:58:18 6E.CME_20140600_6EM4.CME_Fo [CB] #1: There are no continuous futures contracts symbols. Loading data normally. | 2014-03-27 13:58:18 6E.CME_20140600_6EM4.CME_Fo [CB] 15 Min #3: Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 15 Min #3: There are no continuous futures contracts symbols. Loading data normally. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 200 Trades #4: Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 200 Trades #4: There are no continuous futures contracts symbols. Loading data normally. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 5 Min #5: Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 5 Min #5: There are no continuous futures contracts symbols. Loading data normally. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 60 Min #6: Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 60 Min #6: There are no continuous futures contracts symbols. Loading data normally. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 15 Min #7: Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2014-03-27 13:58:19 6E.CME_20140600_6EM4.CME_Fo [CB] 15 Min #7: There are no continuous futures contracts symbols. Loading data normally. | 2014-03-27 13:58:19 TF.ICE_0-IN.TF.201406.1.ICE_IN [CB] 60 Min #8: Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2014-03-27 13:58:19 TF.ICE_0-IN.TF.201406.1.ICE_IN [CB] 60 Min #8: There are no continuous futures contracts symbols. Loading data normally. | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:19 Checking Intraday data file for symbol 6E.20130300.CME_Fo for the date range from 2012-12-17 to 2013-03-18 | 2014-03-27 13:58:19 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-03-27 13:58:19 CTS FIX - Firm: Dorman | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:19 Checking Intraday data file for symbol 6E.20130600.CME_Fo for the date range from 2013-03-18 to 2013-06-17 | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:19 Checking Intraday data file for symbol 6E.20130900.CME_Fo for the date range from 2013-06-17 to 2013-09-16 | 2014-03-27 13:58:19 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:19 Checking Intraday data file for symbol 6E.20131200.CME_Fo for the date range from 2013-09-16 to 2013-12-16 | 2014-03-27 13:58:19 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:19 Checking Intraday data file for symbol 6E.20140300.CME_Fo for the date range from 2013-12-16 to 2014-03-17 | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:19 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:19 6E.20130300.CME_Fo | 2014-03-27 13:58:19 6E.20130600.CME_Fo | 2014-03-27 13:58:19 6E.20130900.CME_Fo | 2014-03-27 13:58:19 6E.20131200.CME_Fo | 2014-03-27 13:58:19 6E.20140300.CME_Fo | 2014-03-27 13:58:19 6E.20140600.CME_Fo | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:19 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:19 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:19 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:19 6E.20130300.CME_Fo | 2014-03-27 13:58:19 6E.20130600.CME_Fo | 2014-03-27 13:58:19 6E.20130900.CME_Fo | 2014-03-27 13:58:19 6E.20131200.CME_Fo | 2014-03-27 13:58:19 6E.20140300.CME_Fo | 2014-03-27 13:58:19 6E.20140600.CME_Fo | 2014-03-27 13:58:19 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:19 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:19 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:19 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:19 6E.20130300.CME_Fo | 2014-03-27 13:58:19 6E.20130600.CME_Fo | 2014-03-27 13:58:19 6E.20130900.CME_Fo | 2014-03-27 13:58:19 6E.20131200.CME_Fo | 2014-03-27 13:58:19 6E.20140300.CME_Fo | 2014-03-27 13:58:19 6E.20140600.CME_Fo | 2014-03-27 13:58:19 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 100 Trades #4: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:19 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:19 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:19 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:19 6E.20130300.CME_Fo | 2014-03-27 13:58:19 6E.20130600.CME_Fo | 2014-03-27 13:58:19 6E.20130900.CME_Fo | 2014-03-27 13:58:19 6E.20131200.CME_Fo | 2014-03-27 13:58:19 6E.20140300.CME_Fo | 2014-03-27 13:58:19 6E.20140600.CME_Fo | 2014-03-27 13:58:19 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:19 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:19 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:19 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:19 6E.20130300.CME_Fo | 2014-03-27 13:58:19 6E.20130600.CME_Fo | 2014-03-27 13:58:19 6E.20130900.CME_Fo | 2014-03-27 13:58:19 6E.20131200.CME_Fo | 2014-03-27 13:58:19 6E.20140300.CME_Fo | 2014-03-27 13:58:19 6E.20140600.CME_Fo | 2014-03-27 13:58:19 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:19 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:19 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:19 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:19 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:19 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:19 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:19 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:19 6E.20130300.CME_Fo | 2014-03-27 13:58:19 6E.20130600.CME_Fo | 2014-03-27 13:58:19 6E.20130900.CME_Fo | 2014-03-27 13:58:19 6E.20131200.CME_Fo | 2014-03-27 13:58:19 6E.20140300.CME_Fo | 2014-03-27 13:58:19 6E.20140600.CME_Fo | 2014-03-27 13:58:19 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:19 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:19 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #7: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:19 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #7: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:20 6E.CME_20140600_6EM4.CME_Fo [CB] 15 Min #8: Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2014-03-27 13:58:20 6E.CME_20140600_6EM4.CME_Fo [CB] 15 Min #8: There are no continuous futures contracts symbols. Loading data normally. | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:20 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:20 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:20 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:20 6E.20130300.CME_Fo | 2014-03-27 13:58:20 6E.20130600.CME_Fo | 2014-03-27 13:58:20 6E.20130900.CME_Fo | 2014-03-27 13:58:20 6E.20131200.CME_Fo | 2014-03-27 13:58:20 6E.20140300.CME_Fo | 2014-03-27 13:58:20 6E.20140600.CME_Fo | 2014-03-27 13:58:20 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] #1: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:20 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:20 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:20 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:20 6E.20130300.CME_Fo | 2014-03-27 13:58:20 6E.20130600.CME_Fo | 2014-03-27 13:58:20 6E.20130900.CME_Fo | 2014-03-27 13:58:20 6E.20131200.CME_Fo | 2014-03-27 13:58:20 6E.20140300.CME_Fo | 2014-03-27 13:58:20 6E.20140600.CME_Fo | 2014-03-27 13:58:20 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 15 Min #3: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:20 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:20 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:20 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:20 6E.20130300.CME_Fo | 2014-03-27 13:58:20 6E.20130600.CME_Fo | 2014-03-27 13:58:20 6E.20130900.CME_Fo | 2014-03-27 13:58:20 6E.20131200.CME_Fo | 2014-03-27 13:58:20 6E.20140300.CME_Fo | 2014-03-27 13:58:20 6E.20140600.CME_Fo | 2014-03-27 13:58:20 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 250 Trades #4: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:20 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:20 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:20 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:20 6E.20130300.CME_Fo | 2014-03-27 13:58:20 6E.20130600.CME_Fo | 2014-03-27 13:58:20 6E.20130900.CME_Fo | 2014-03-27 13:58:20 6E.20131200.CME_Fo | 2014-03-27 13:58:20 6E.20140300.CME_Fo | 2014-03-27 13:58:20 6E.20140600.CME_Fo | 2014-03-27 13:58:20 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 5 Min #5: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130300.CME_Fo to next contract occurs at 2013-03-18 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130600.CME_Fo to next contract occurs at 2013-06-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20130900.CME_Fo to next contract occurs at 2013-09-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17 | 2014-03-27 13:58:20 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16 | 2014-03-27 13:58:20 Intraday data file for 6E.20130300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H13 for the date range from 2012-12-17 to 2013-03-13 | 2014-03-27 13:58:20 Intraday data file for 6E.20130600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M13 for the date range from 2013-03-18 to 2013-06-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20130900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6U13 for the date range from 2013-06-17 to 2013-09-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20131200.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-11 | 2014-03-27 13:58:20 Intraday data file for 6E.20140300.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-12 | 2014-03-27 13:58:20 Intraday data file for 6E.20140600.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 0 | 2014-03-27 13:58:20 Symbols used for 6E.20140600.CME_Fo continuous contract chart: | 2014-03-27 13:58:20 6E.20130300.CME_Fo | 2014-03-27 13:58:20 6E.20130600.CME_Fo | 2014-03-27 13:58:20 6E.20130900.CME_Fo | 2014-03-27 13:58:20 6E.20131200.CME_Fo | 2014-03-27 13:58:20 6E.20140300.CME_Fo | 2014-03-27 13:58:20 6E.20140600.CME_Fo | 2014-03-27 13:58:20 Volume based rollover from 6E.20130300.CME_Fo to 6E.20130600.CME_Fo occurs at 2013-03-15 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130600.CME_Fo to 6E.20130900.CME_Fo occurs at 2013-06-14 | 2014-03-27 13:58:20 Volume based rollover from 6E.20130900.CME_Fo to 6E.20131200.CME_Fo occurs at 2013-09-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20131200.CME_Fo to 6E.20140300.CME_Fo occurs at 2013-12-13 | 2014-03-27 13:58:20 Volume based rollover from 6E.20140300.CME_Fo to 6E.20140600.CME_Fo occurs at 2014-03-14 | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130300.CME_Fo Open price on 2013-03-15 is 1.3002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130600.CME_Fo Open price on 2013-03-15 is 1.301. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130300.CME_Fo price difference to 6E.20130600.CME_Fo is 0.00080000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130600.CME_Fo Open price on 2013-06-14 is 1.3376. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130900.CME_Fo Open price on 2013-06-14 is 1.3378. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130600.CME_Fo price difference to 6E.20130900.CME_Fo is 0.00020000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130900.CME_Fo Open price on 2013-09-13 is 1.33. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20131200.CME_Fo Open price on 2013-09-13 is 1.3306. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20130900.CME_Fo price difference to 6E.20131200.CME_Fo is 0.00060000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20131200.CME_Fo Open price on 2013-12-13 is 1.3749. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20140300.CME_Fo Open price on 2013-12-13 is 1.3748. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20131200.CME_Fo price difference to 6E.20140300.CME_Fo is -0.00010000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20140300.CME_Fo Open price on 2014-03-14 is 1.3873. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20140600.CME_Fo Open price on 2014-03-14 is 1.387. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: 6E.20140300.CME_Fo price difference to 6E.20140600.CME_Fo is -0.00030000. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20130300.CME_Fo is 12.000001. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20130600.CME_Fo is 4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20130900.CME_Fo is 2.0000002. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20131200.CME_Fo is -4.0000005. | 2014-03-27 13:58:20 6E.20140600.CME_Fo [CBV] 60 Min #6: Back adjust amount for symbol 6E.20140300.CME_Fo is -3.0000002. | 2014-03-27 13:58:20 Date rule based rollover from TF.20130300.ICE_IN to next contract occurs at 2013-03-07 | 2014-03-27 13:58:20 Date rule based rollover from TF.20130600.ICE_IN to next contract occurs at 2013-06-13 | 2014-03-27 13:58:20 Date rule based rollover from TF.20130900.ICE_IN to next contract occurs at 2013-09-12 | 2014-03-27 13:58:20 Date rule based rollover from TF.20131200.ICE_IN to next contract occurs at 2013-12-12 | 2014-03-27 13:58:20 Date rule based rollover from TF.20140300.ICE_IN to next contract occurs at 2014-03-13 | 2014-03-27 13:58:20 Date rule based rollover from TF.20140600.ICE_IN to next contract occurs at 2014-06-12 | 2014-03-27 13:58:20 Intraday data file for TF.20130300.ICE_IN exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Daily data file for symbol TF.20130300.ICE_IN existed and is empty. Skipping download. | 2014-03-27 13:58:20 Intraday data file for TF.20130600.ICE_IN exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Daily data file for symbol TF.20130600.ICE_IN existed and is empty. Skipping download. | 2014-03-27 13:58:20 Intraday data file for TF.20130900.ICE_IN exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Daily data file for symbol TF.20130900.ICE_IN existed and is empty. Skipping download. | 2014-03-27 13:58:20 Intraday data file for TF.20131200.ICE_IN exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Daily data file for symbol TF.20131200.ICE_IN existed and is empty. Skipping download. | 2014-03-27 13:58:20 Intraday data file for TF.20140300.ICE_IN exists and is empty. Skipping Intraday data download. | 2014-03-27 13:58:20 Daily data file for symbol TF.20140300.ICE_IN existed and is empty. Skipping download. | 2014-03-27 13:58:20 Checking Intraday data file for symbol TF.20140600.ICE_IN for the date range from 2014-03-13 to 0 | 2014-03-27 13:58:20 Daily data file for symbol TF.20140600.ICE_IN existed and is empty. Skipping download. | 2014-03-27 13:58:20 Symbols used for TF.20140600.ICE_IN continuous contract chart: | 2014-03-27 13:58:20 TF.20130300.ICE_IN | 2014-03-27 13:58:20 TF.20130600.ICE_IN | 2014-03-27 13:58:20 TF.20130900.ICE_IN | 2014-03-27 13:58:20 TF.20131200.ICE_IN | 2014-03-27 13:58:20 TF.20140300.ICE_IN | 2014-03-27 13:58:20 TF.20140600.ICE_IN | 2014-03-27 13:58:20 Unable to determine transition date based on volume from files: C:\SierraChart\Data\TF.20130300.ICE_IN.dly, C:\SierraChart\Data\TF.20130600.ICE_IN.dly | 2014-03-27 13:58:20 Unable to determine transition date based on volume from files: C:\SierraChart\Data\TF.20130600.ICE_IN.dly, C:\SierraChart\Data\TF.20130900.ICE_IN.dly | 2014-03-27 13:58:20 Unable to determine transition date based on volume from files: C:\SierraChart\Data\TF.20130900.ICE_IN.dly, C:\SierraChart\Data\TF.20131200.ICE_IN.dly | 2014-03-27 13:58:20 Unable to determine transition date based on volume from files: C:\SierraChart\Data\TF.20131200.ICE_IN.dly, C:\SierraChart\Data\TF.20140300.ICE_IN.dly | 2014-03-27 13:58:20 Unable to determine transition date based on volume from files: C:\SierraChart\Data\TF.20140300.ICE_IN.dly, C:\SierraChart\Data\TF.20140600.ICE_IN.dly | 2014-03-27 13:58:20 TF.20140600.ICE_IN [CBV] 15 Min #9: Performing continuous futures contract back adjustment calculations. | 2014-03-27 13:58:20 Error while getting daily open price with date 2013-03-10 from file. C:\SierraChart\Data\TF.20130300.ICE_IN.dly. Error: Encountered end of file. | |
[2014-03-27 18:14:58] |
This Message Log does not show a connection to the CTS FIX server. We need to see it again after you are connected to CTS. And can you describe the problem you are seeing with 6E.20140600.CME_Fo . Maybe we are not understanding what you mean. We assumed that there is a problem with real-time chart updating. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-28 17:11:24
[2014-03-28 12:25:03] |
User81946 - Posts: 9 |
I have removed all schedules 6E.CME.... I have removed all files 6E... in the catalogue .../data Now all works. Thanks. |
[2014-03-28 17:11:38] |
This is good. Let us know if there any further problems.
