Date/Time: Wed, 22 Apr 2026 02:32:27 +0000
What files to save B4 a computer crash
View Count: 1318
| [2014-03-25 23:37:24] |
| rick e - Posts: 51 |
Hi folks. I had a bad thing happen to me yesterday - I had a computer CRASH. Haven't had one of those in years! It seems a rather nasty worm got into the works. It's ok now, but I was wondering what specific files I should regularly backup if I ever had to start all over again by reinstalling SC and hopefully NOT having to re-construct and re-configure all of those lovely chartbooks that I have so carefully crafted over the years. Thanks for any input - Rick
| [2014-03-26 00:38:50] |
we recommend backing up the entire Sierra Chart folder. To save space you can exclude files with a "scid" file extension.
