Date/Time: Fri, 06 Nov 2026 08:17:24 +0000
Severe lag when changing input values in the interface
View Count: 787
[2021-09-21 22:46:27]
cmet - Posts: 743
Been experiencing lag when selecting study inputs that can be modified using the lower text box.
If I pull up the study, select the input in the upper right pane, there is a 2-3 second lag before the lower editing box is highlighted so that the input can be changed. Doesn't even allow me to select it manually for 2-3 seconds. If I try to select, I actually get the windows error bell.
Not seeing any spikes in CPU core usage so not sure what this is.
Any known causes?
Date Time Of Last Edit: 2021-09-21 22:48:37
[2021-09-21 23:10:49]
It would have to be a high CPU load within the main thread of Sierra Chart. So you would have to look at causes of high CPU usage:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
If there is another issue, it is going to be a system-level issue.
