Date/Time: Fri, 18 Jul 2025 23:01:13 +0000
session times
View Count: 2941
[2014-03-25 12:00:23]
narcese - Posts: 58
I wish to start my session at 20:00:00 and finish at 19:59:59. However, my charts reverts back to 19:00:00 and 18:00:00. I am baffled as to why to the desired times will not hold. Any thoughts?
[2014-03-25 14:27:17]
vegasfoster - Posts: 444
If you change to another symbol or to another contract for the same symbol, the session times will revert to their defaults. If you want to change the defaults for a symbol, then go to Global Settings >> Symbol Settings >> Intraday Tab and then select the symbol you want to change, make changes and click OK.
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes
[2014-03-25 16:56:07]
Refer to:
