Date/Time: Fri, 06 Nov 2026 08:27:20 +0000
Auto Load Tools
View Count: 778
| [2021-09-16 13:18:07] |
| quin6 - Posts: 22 |
Hi when doing 'Active Analysis' while trading, I like to constantly mark up my chart. I'm experiencing some inconvenience with the tools. Which is every time I mark my chart, I have to re-click to reload my tool. Is there a way to have the tool auto loaded kind of like chart values? Thanks. Date Time Of Last Edit: 2021-09-16 13:18:53
| [2021-09-16 15:52:22] |
| John - SC Support - Posts: 48449 |
We are not sure we are understanding the issue you are describing. But it sounds like your tool selection is changing after you use a particular tool and you do not want it to do this. If this is the case, then the reason this is occurring is because you have the following setting selected to do this exactly: Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options) In order to not have it change, set the above setting to None. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
