Date/Time: Wed, 13 May 2026 10:34:23 +0000
Vertical Line bug ?
View Count: 1290
| [2014-03-25 10:04:15] |
| doctor.scalp - Posts: 18 |
Hello, Can you check this screenshot http://www.sierrachart.com/image.php?l=1395741704720.png ? As you can see we have multiple vertical line when we "lock" fill space. Is it normal ? Thanks, |
| [2014-03-25 20:02:21] |
The Vertical Grid documentation here has been updated to explain why you see what you do: https://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#Vgrid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
