Date/Time: Fri, 06 Nov 2026 08:27:24 +0000
Do I require Denali Exchange
View Count: 900
| [2021-09-15 16:06:47] |
| WizzyTrader - Posts: 5 |
I have recently switched Brokers and the new one requires CME data for $13 a month. Previously I was with AMP Futures and wasn't required so I activated Denali Exchange. Do I still require Denali Exchange data feed or is it no longer required? Thanks |
| [2021-09-15 17:29:20] |
| John - SC Support - Posts: 48449 |
What trading service does your new broker support (CQG, Rithmic, TT)?
| [2021-09-15 17:42:12] |
Gain Capital thru CQG I believe
| [2021-09-15 18:04:37] |
Theoretically it would be possible to get the data from Gain Capital, but it is not an interface that we have kept up and we will not be doing any further work with it. Therefore, if there comes a time when they make a change that would require us to do something, then it simply will not work any longer. We also do not give any support for issues related to data from Gain Capital. As you can see, we really prefer that you use our data, as it is something that is within our control and it gives you the best overall performance with Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-16 10:09:17] |
Yes you really should use the Denali Exchange Data Feed when using gain capital and gain capital support will be terminated at some point in the future. Documentation for the Denali Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-09-16 10:09:36
