Date/Time: Fri, 09 Oct 2026 07:22:55 +0000
Lines Indicating Transition Points to Next Futures Contract
View Count: 3021
| [2014-03-25 08:44:39] |
We have implemented a new feature to display vertical lines at the dates in a chart when there is a transition to the next futures contract in a Continuous Futures Contract chart. Here is an example: http://www.sierrachart.com/image.php?l=139573507287.png This will be out in the next release, coming out later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-25 08:46:01
| [2014-03-27 09:36:14] |
This feature is now available in Prerelease 1112. It can be enabled with Chart >>Show Rollover Dates. Now there can be no doubt, where rollover occurs. This is another advantage when using the Sierra Chart Continuous Futures Contract feature. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-27 09:36:39
| [2014-03-29 02:34:40] |
| vegasfoster - Posts: 444 |
Thank you. Simple, but incredibly useful.
