Date/Time: Thu, 02 May 2024 06:21:52 +0000
Is there a setting to change the floating window default blue color?
View Count: 457
[2021-09-15 05:00:42] |
HumblyTrading - Posts: 170 |
Hello, After going through the global color settings, attempting to create a "dark mode" for the various charts, I did not find a setting to change the actual window blue color where each floating panel has the blue outline and title bar. Would you mind letting me know if this is possible to change in the application settings? Please see attached image to understand the blue color I am describing. http://www.sierrachart.com/image.php?Image=1631682004607.png Thank you, Mike |
MikeT2021-09-15_12-56-03_AM.png / V - Attached On 2021-09-15 04:57:41 UTC - Size: 431.18 KB - 136 views Attachment Deleted. |
[2021-09-15 08:53:52] |
The title bar color is controlled by the operating system.
