Date/Time: Fri, 06 Nov 2026 08:27:33 +0000
request on the retracement tool
View Count: 771
| [2021-09-14 16:19:33] |
| User274507 - Posts: 37 |
Hi, I use the retracement tool for projection and retracement with the system I use. Could you add one more line on the retracmeent tool configuration so I can add an extra % to it? There is 9 at the moment but would like 10. This would would make my life easier as I wouldn't have to use two configuration versions and keep switching and replacing. many thanks for your time Nick |
| [2021-09-14 16:27:25] |
| John - SC Support - Posts: 48449 |
You can add additional lines to the retracement tool. Once the drawing is done, right-click and select the Chart Drawing Properties then on the "Levels" tab select the + button, this will add one additional level. Continue to select the + button to add as many levels as you need. Refer to the following for more information: Chart Drawing Tools: Common Tool Configuration Settings and Chart Drawing Properties Note that you can also do this to the configurations if you want to do it ahead of time and not after the drawing is done. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
