Date/Time: Sun, 28 Apr 2024 06:31:06 +0000
Accessing replay results using GetTradeStatisticsForSymbolV2
View Count: 523
[2021-09-11 16:03:12] |
User99735 - Posts: 234 |
Hi, Query on a replay run in SIM account started by sc.StartChartReplay() / sc.StartChartReplayNew() and stopped with sc.StopChartReplay()? - Will it be possible to access the results of the replay using sc.GetTradeStatisticsForSymbolV2()? - Any way to specify the end date of the replay using the above functions? - Will the Trade Statistics be reset at start of replay using sc.StartChartReplay()? Vivek |
[2021-09-11 23:22:17] |
Yes during the replay and after the replay finishes this information will be valid: - Will it be possible to access the results of the replay using sc.GetTradeStatisticsForSymbolV2()?
- Any way to specify the end date of the replay using the above functions? No.- Will the Trade Statistics be reset at start of replay using sc.StartChartReplay()? Yes.
[2021-09-15 08:39:38] |
Hi, Thanks for the response. Currently the following functions are available to set the study inputs via ACSIL sc.SetChartStudyInputInt(). sc.SetChartStudyInputFloat(). sc.SetChartStudyInputString(). Can we have Set/Get equivalents of the following input functions: sc.Input[].SetDescription() sc.Input[].SetYesNo() sc.Input[].SetInputDataIndex() sc.Input[].SetDate() sc.Input[].SetTime() sc.Input[].SetTimeAsSCDateTime() sc.Input[].SetDateTime() sc.Input[].SetCustomInputIndex() sc.Input[].SetColor() sc.Input[].SetTimePeriodType() sc.Input[].SetAlertSoundNumber() sc.Input[].SetStudyID() sc.Input[].SetChartNumber() sc.Input[].SetChartStudySubgraphValues() sc.Input[].SetStudySubgraphValues() sc.Input[].SetChartStudyValues() sc.Input[].SetString() sc.Input[].SetPathAndFileName() and sc.SetChartStudyInputType() - indicating the type set/get by the input. |
[2021-09-15 15:19:01] |
This is not anything we can spend time with now.
[2021-09-15 15:24:10] |
Thanks, please take it as an enhancement request for future.
