Date/Time: Fri, 03 May 2024 09:24:02 +0000
Unavailability of Symbols when Using Sierra Chart Package 3 in a
View Count: 1969
[2013-04-23 08:39:13] |
Riche - Posts: 20 |
Hi there, I had a new Pc here. After installing sierra chart in my new Pc, I found that lots of symbols are not available as compared to my old Pc. Pls help. Tx. |
[2013-04-23 08:41:23] |
Riche - Posts: 20 |
For example, symbol #E6 & ^EURUSD were unavailable.
[2013-04-23 09:02:51] |
Make sure you set Sierra Chart for the Service you want to use. Please see this page: http://www.sierrachart.com/index.php?l=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-23 12:56:22] |
Riche - Posts: 20 |
Yup, currently I am subscribed to PACKAGE 3 Sierra Chart Historical Daily and Intraday Data Service. My old PC runs just fine. But not my new PC. I did not run them simultaneously though.... |
[2013-04-23 14:04:19] |
Please select File >> Data/Trade Service Settings. What is the Service set to?
