Date/Time: Fri, 06 Nov 2026 08:40:46 +0000
Number Bars
View Count: 695
[2021-09-09 16:31:39]
Sginatta - Posts: 2
I am putting the number bars study and configurating it to view bid ask x sell ask but it appears horizontally. I checked you help menu and it only says to put the scale in automatic. i have done that and it still is the same horizontally. Please provide help of what is happening andd further intructions on how to put the number bars vertically.
Kind Regards,
Stefano Ginatta
[2021-09-09 17:21:26]
First, make sure you scale is set to Automatic and reset your scaling. It sounds like your scaling is just way off and you are only seeing one price line. Refer to the information on this page:
Chart Scale and Scale Adjusting
You will probably have to scale back out again after doing the reset, but you should be able to understand where you are at that point.
If that does not resolve your issue, then we need to see an image so we can understand what you are seeing.
