Date/Time: Fri, 06 Nov 2026 08:40:02 +0000
enable Rithmic Connection
View Count: 804
| [2021-09-09 16:11:55] |
| User905973 - Posts: 1 |
I signed up for SC free 15-day trial and I wanted to integrate it with Rithmic. However, following the Connection instructions, I don't see the options to select in the >Server List in >Data/Trade Service Settings. I am unable to do anything at this point. Is there something that you need to activate on your end? |
| [2021-09-09 17:12:05] |
| John - SC Support - Posts: 48449 |
No, there is nothing we need to do on our end. Did you follow through these Setup Instructions: Rithmic Trading Platform Service If the issue is related to the Server list, then note in Step #7 it tells you to exit the Data/Trade Service Settings after selecting the Rithmic Direct - DTC service, as the system needs to get the server information from Rithmic and it can take a few minutes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
