Date/Time: Sat, 12 Jul 2025 00:55:57 +0000
help creating continous contracts...
View Count: 1211
[2014-03-24 13:54:06] |
User84117 - Posts: 3 |
I'm currently in my trial of SC. I've been trying to create continuous contracts of the NQ (nasdaq 100). I've read the instructions and checked the the appropriate boxes but I can't get anything that goes back further than the current contract. (I'm trying to create a daily chart and an intraday chart that are continuous). Should I not enter the front month when creating a continuous daily chart? Sorry for such a basic question. I'm running windows 8.1 and I am running the latest version of SC. |
[2014-03-24 17:58:51] |
What do you have Global Settings >> Data/Trade Service Settings >> Service set to?
[2014-03-24 21:03:37] |
I was using the SC Historical Data feed. Thanks for the help.
[2014-03-25 17:26:25] |
bump
[2014-03-25 17:29:27] |
Follow through the instructions here again: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html You also might want to re-download the data in the chart. The instructions for that are on the same page. If the chart still does not have the data that you need, then post an image of it, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Before posting the image, reduce the bar spacing in the chart by pressing the down arrow key on the keyboard. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
