Date/Time: Mon, 16 Nov 2026 21:09:43 +0000
[User Discussion] - save local settings of tading dom for chart
View Count: 676
| [2021-09-05 11:04:57] |
| User278398 - Posts: 296 |
i changed local settings of the trading dom for chart, when i open a new Dom for a new chart i don't get my custom dom. how can i save the custom template of Dom and open it for a new chart? |
| [2021-09-06 06:11:15] |
Refer to: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
