Date/Time: Fri, 06 Nov 2026 08:47:09 +0000
Show value of indicator on chart
View Count: 1383
| [2021-09-02 14:45:11] |
| User58776 - Posts: 18 |
Dear, please see attached file with my chart setup. The indicator at the bottom is the nyse tick indicator. I would like to have the real time value of this indicator directly on my chart on top displayed (e.g. as the countdown timer that you see there) Is that possible? thanks in advance best regards Jeroen. |
Private File |
| [2021-09-02 16:47:54] |
| John - SC Support - Posts: 48449 |
Refer to the study Text Display for Study: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-02 18:38:38] |
Thanks for this! Small additional question: the value now displays 2 characters after the comma, while I want it to display only the full number. So e;g. not 200.00 but 200. It is a detail question, so, no issue if this is not possible or not considered a support question. best regards and thanks again Jeroen |
| [2021-09-02 19:08:49] |
You would need to change the Value Format for the Text Display for Study. Refer to the following: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
