Date/Time: Sun, 29 Nov 2026 04:18:35 +0000
Error message connecting to Rithmic
View Count: 930
[2021-08-30 01:59:18]
User109175 - Posts: 28
Hi I get the attached error message when trying to connect to Rithmic (via OneUpTrader).
Could you assist at all?
Private File
[2021-08-30 04:00:19]
Hi I found this thread - Rithmic Bridge Files
and I have created the Rim folder and moved the downloaded bridge files across but my data isnt updating to today. Is this a OneUpTrader issue as they are supplying the data (Ive moved off Denali and signed up with OneUp which I believe includes the data feed)
[2021-08-30 07:26:49]
You will want to use the new Rithmic connection documented here:
Rithmic Trading Platform Service: Setup Instructions
You will need to update to the current version of Sierra Chart:
You will have data issues, unless you use the Denali Exchange Data Feed. Especially with historical data. So you do have to continue to use the Denali Exchange Data Feed:
Date Time Of Last Edit: 2021-08-30 07:27:41
