Date/Time: Mon, 23 Nov 2026 01:57:44 +0000
Real time data
View Count: 839
| [2021-08-26 11:00:25] |
| Bankson H - Posts: 15 |
Dear Mr/Mrs, Do you need to have a funded account to use real time data? Is it possible to use the real time data only for analysis? Regards |
| [2021-08-26 12:03:11] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: Is Historical and Real-time Data Included? Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-26 12:32:02] |
I have read the page and it's a little bit confusing. I want to use the real time futures data from the CME-exchange and I want to use it only for analysis, So I don't have a funded futures account. The execution of market orders happens on a different platform which is not supported by sierra chart. |
| [2021-08-26 17:05:39] |
In this case, you need to use this solution: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-26 18:40:08] |
Thanks for your reply. So when I open a trading account with AMP or Stage 5 and put 100 USD in it, can I let the money there and be inactive on that account or do I also need to take some trades to show that I am active? I think, I am gonna use stage 5. When i put the money in the account and I pay for the denali exchange data feed, will I get the real time data automatically? |
| [2021-08-26 19:55:51] |
It can be inactive. That is fine. When i put the money in the account and I pay for the denali exchange data feed, will I get the real time data automatically? Yes but they will need to set up the account on the Sierra Chart Order Routing Service.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-26 19:56:03
