Date/Time: Fri, 26 Apr 2024 16:58:52 +0000
Huge amount of time lost searching study settings
View Count: 556
[2021-08-25 09:11:48] |
BenjFlame - Posts: 305 |
Sierrachart is one of the richest trading software with an incredible amount of settings. I think I spend 50% of my time setting up Sierrachart searching for a particular study setting that I know is buried somewhere in the setting dialog box. For example each time I pull up the number bar study setting, I know I will suffer with those little characters searching for the particular setting I need. I suggest you implement on each dialog box of studies, and on the study selection itself, an autocomplete search box. Date Time Of Last Edit: 2021-08-25 09:17:58
[2021-10-20 16:50:33] |
Trader & Sierra++ developer - Posts: 105 |
+1 Same for graphics settings. I know you don't want to spend any time on ergonomics. Is there any other way to update settings ? Maybe an external application that would be able to generate or update settings files ? If none, i would be very happy to code such a little helper tool. I'm an experienced coder. Don't hesitate contacting me for this. |
[2022-06-02 19:03:54] |
Thanks for implementing this. Will it be extended to other dialogs, like study dialogs? |
