Date/Time: Fri, 20 Nov 2026 02:01:56 +0000
Trade Simulation Mode Wont Turn On
View Count: 1567
| [2021-08-23 22:50:05] |
| OrbitalD - Posts: 29 |
Trade Simulation Mode Wont Turn On The Trade Simulation Mode option is under the Trade Tab but it wont turn on, no check mark when clicked. When Replay Chart is selected and the chart is replayed it inters Simulation Mode and the check mark appears next to Trade Simulation Mode. |
| [2021-08-24 13:43:26] |
Now after turning on Sim Mode with Chart Replay, Sim Mode wont turn off even when the Chart Replay window is closed.
| [2021-08-24 14:16:47] |
This is explained here: Simulated Futures Trading Service: Using Internal Sierra Chart Trade Simulation Mode (Using Internal Sierra Chart Trade Simulation Mode) Now after turning on Sim Mode with Chart Replay, Sim Mode wont turn off even when the Chart Replay window is closed. This is because there is one chart that is still replaying.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-24 14:17:34
| [2021-08-24 14:58:07] |
Thank you. Found the replay chart, was able to turn off Sim Mode, and now its back to the original problem. "Trade Simulation Mode Wont Turn On The Trade Simulation Mode option is under the Trade Tab but it wont turn on, no check mark when clicked. When Replay Chart is selected and the chart is replayed it inters Simulation Mode and the check mark appears next to Trade Simulation Mode." Any ideas on this problem? Date Time Of Last Edit: 2021-08-24 14:59:25
| [2021-08-24 15:22:48] |
OK I think I figured it out. Switched to SC All Data and its working now. Thanks, David |
| [2021-08-24 18:26:39] |
| John - SC Support - Posts: 48597 |
If you had your service set to one of the "Trading Evaluator" options, then you can NOT turn on Simulation Mode. As you found, you need to switch your service to SC Data - All Services to be able to run in Simulation mode again without submitting to the Trading Evaluator service.
