Date/Time: Mon, 06 May 2024 12:51:55 +0000
[User Discussion] - TPO Count Above Settle Close
View Count: 613
[2021-08-20 18:12:17] |
User354746 - Posts: 3 |
How can I display the TPO count of the Overnight Session, above the Settle of the previous RTH session, in relation to the Total TPO count of the ON, expressed as a percentage?
[2021-08-23 14:32:13] |
John - SC Support - Posts: 31379 |
There is no built in way to get that information. The only way to do it would be to create a Custom Study using ACSIL. In particular, refer to this function to give you access to the data you want: sc.GetStudyProfileInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-14 17:53:36] |
How stable are those member functions from scGetStudyProfileInformation? Does a paid custom study have to be frequently adjusted because of any change done in Sierra?
[2021-10-14 18:16:59] |
We are not sure what you are asking. Does a paid custom study have to be frequently adjusted because of any change done in Sierra?
Frequently - no, but there are occasions where updates need to be made. We had a big change about a year ago, but before that it was several years before an update needed to be made. We have marked this as a User Discussion for others to give their opinions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-14 18:21:39] |
Stability in returning proper price levels from a chosen profile? Like m_OpenPrice, m_HighestPrice, etc...
[2021-10-14 23:04:22] |
Extremely stable. You are basically getting the same data that we use internally for that information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-17 15:40:59] |
bradh - Posts: 854 |
I have a study that does this. Sent you a direct message request. BradH |
