Date/Time: Sun, 08 Nov 2026 00:35:06 +0000
selecting multiple tool (drawings) at once
View Count: 1622
| [2021-08-19 18:35:40] |
| quin6 - Posts: 22 |
Hi there, wishing you a great day & week! I use the rectangle drawing to measure variance and like to place it next to the current price to calculate potential moves. I have multiple of these rectangle and it would make life so much easier if i could select all of them at once and move them all at once! How would one go about doing this? Thanks! |
| Attachment Deleted. |
| [2021-08-19 18:55:51] |
This is not supported. There are some operations that can be performed on multiple chart drawings through the Manage Chart Drawings Window: Chart Drawing Tools: Manage Chart Drawings However, it is not supported to move them at once. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
