Date/Time: Sat, 27 Apr 2024 03:04:41 +0000
Spreadsheets not saved in chartbook
View Count: 975
[2014-03-21 13:35:37] |
gfs117 - Posts: 24 |
Hi, Since upgrading to the latest version, it seems that I can no longer save a spreadsheet within a chartbook. When I open a spreadsheet (or create a new spreadsheet) in a chartbook and then save and close the chartbook, the spreadsheet remains open. Also when I open the chartbook, the spreadsheet is not opened with it. Old chartbooks with existing spreadsheets in them still work fine. Could you look into this issue please? Thank you. |
[2014-03-21 18:03:57] |
This is how it always has been. It might be different in the non-CLR version but Spreadsheets in the non-CLR version are still under development. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-21 18:37:11] |
What do you mean? The docs say "All chart windows, Time and Sales windows, Market Depth windows, Trade windows, Trade DOM windows, and Spreadsheets are contained within Chartbooks."
[2014-03-21 18:51:38] |
Spreadsheets are definitely not part of Chartbooks in the CLR version of Sierra Chart unless they are added through the Spreadsheet studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
