Date/Time: Sun, 08 Nov 2026 00:35:06 +0000
connection error
View Count: 890
[2021-08-17 19:03:07]
User491299 - Posts: 26
Good day. I know that you don`t like questions about Rithmic but I will ask you. Few times during a day I lose my connection for 10-15 seconds and after that it works okay.
could you help me with that?
Rithmic Trading | Message from server: Server Alert: PnL Connection - Heartbeat has been quiet for 40.862 seconds. | 2021-08-17 16:55:13.008
Rithmic Trading | Message from server: Deleting API object. | 2021-08-17 16:55:13.008
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Closed | 2021-08-17 16:55:13.008
Rithmic Trading | Message from server: Server Alert: PnL Connection Closed | 2021-08-17 16:55:13.010
Rithmic Trading | Message from server: Server Alert: Trading System Connection Closed | 2021-08-17 16:55:13.037
Rithmic Trading | Message from server: Server Alert: Market Data Connection Closed | 2021-08-17 16:55:13.040
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-08-17 16:55:13.205
DTC Client socket (1) | CloseSocket call. | 2021-08-17 16:55:13.230
Connection to the external service has been lost. | 2021-08-17 16:55:13.233
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-08-17 16:55:13.237
DTC Client socket (1) | Closed. | 2021-08-17 16:55:13.237
Rithmic Trading | Waiting for socket receive thread to end | 2021-08-17 16:55:13.383
DTC Client socket (0) | CloseSocket call. | 2021-08-17 16:55:13.383
Rithmic Trading | Disconnected. | 2021-08-17 16:55:13.399
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-08-17 16:55:13.399
Rithmic Trading | Port for executable: 57702 | 2021-08-17 16:55:15.400
Listening socket (0). Port 57702 | Closed listening socket. | 2021-08-17 16:55:15.400
WSACleanup called. | 2021-08-17 16:55:15.400
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-08-17 16:55:15.400
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-08-17 16:55:15.404
Rithmic Trading | Bridge process is running. | 2021-08-17 16:55:17.401
Rithmic Trading | Connecting to the server 127.0.0.1. Port 57702 | 2021-08-17 16:55:17.401
DTC Client socket (1) | Creating socket. | 2021-08-17 16:55:17.402
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-08-17 16:55:17.402
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-08-17 16:55:17.402
Rithmic Trading | Network connection to server complete. | 2021-08-17 16:55:17.405
Rithmic Trading | Starting socket receive thread. | 2021-08-17 16:55:17.405
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-08-17 16:55:17.405
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-08-17 16:55:17.407
Rithmic Trading | Sending logon request message. | 2021-08-17 16:55:17.407
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-08-17 16:55:17.412
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-08-17 16:55:17.414
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2021-08-17 16:55:17.414
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-08-17 16:55:18.933
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2021-08-17 16:55:19.372
Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2021-08-17 16:55:19.818
Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2021-08-17 16:55:20.142
Rithmic Trading | Message from server: subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2021-08-17 16:55:20.439
Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2021-08-17 16:55:20.695
Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2021-08-17 16:55:20.969
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2021-08-17 16:55:21.540
Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2021-08-17 16:55:21.846
Rithmic Trading | Received logon response. | 2021-08-17 16:55:22.411
Rithmic Trading | Server Name: SC DTC Bridge. | 2021-08-17 16:55:22.411
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-08-17 16:55:22.411
Rithmic Trading | Successfully connected. IB='OneUpTrader', Firm='OneUpTrader'. | 2021-08-17 16:55:22.411
Rithmic Trading | Trading is supported. | 2021-08-17 16:55:22.411
[2021-08-17 19:11:46]
John - SC Support - Posts: 48459
According to the following message, you are still using the older Rithmic interface:
Rithmic has put out their new interface for Sierra Chart, so we recommend using that interface instead of the old one. To do this, follow these setup instructions:
Rithmic Trading Platform Service: Setup Instructions
[2021-08-18 18:31:39]
Thanks a lot. But now I have another problem with rithmic historic data I just can not see it. The link you send me says that I must use service package 10. I activated it but still no historic data, should I buy denali to use historic data? I want to emphasize that I don`t want to use denali real time data.
[2021-08-18 18:36:11]
There is generally a lack of historic data from Rithmic, and other data sources. The only solution is to use the Denali Exchange Data Feed for your Real-Time data, which will also give you the historical data you want. Refer to the information here:
[2021-08-18 20:29:41]
Thank you, Sir. Is that means that rithmic cant get me even 5 days of historic data?
[2021-08-19 13:30:23]
That is something you need to check with them about. We are just showing what we are getting.
[2021-08-19 14:09:01]
You have no exchanges active with the Denali Exchange Data Feed.
You need to activate them from here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed
You can just activate the exchange fees that provide top of book data for the least cost.
Date Time Of Last Edit: 2021-08-19 14:09:23
