Date/Time: Wed, 02 Jul 2025 00:29:12 +0000
Failure to connect to data and trade server
View Count: 1639
[2014-03-21 03:05:24]
bullyboy - Posts: 11
Loaded TWS and Sierra into my new computer.Checked all the ports,sockets, password etc.- they are ok.Cannot get connected but I am able to log into both Tws and Sierra. I have downloaded the latest version of TWS - 936.9 and Sierra charts - 1107. THe only strange thing I noticed is at the top of the sierra log-in after the date and time it says [sim]. Hope you can help me with this problem. thank you. Copy of error message below.
Software version: 1107 | 2014-03-20 21:34:59
Usage end date: 2014-06-04 | 2014-03-20 21:34:59
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-03-20 21:34:59
Active service: Interactive Brokers | 2014-03-20 21:34:59
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-03-20 21:34:59
2014-03-20 21:34:59 Local computer clock time | 2014-03-20 21:34:59
2014-03-21 01:34:59 GMT time | 2014-03-20 21:34:59
2014-03-20 21:34:59 Time zone adjusted time | 2014-03-20 21:34:59
Time difference to server time: 6 seconds. | 2014-03-20 21:34:59
Program path: C:\SierraChart\ | 2014-03-20 21:34:59
Data Files path: C:\SierraChart\Data\ | 2014-03-20 21:34:59
OS Version Number: 6.1 | 2014-03-20 21:34:59
Checking for new symbol settings for ib | 2014-03-20 21:34:59
Symbol settings are up-to-date for ib | 2014-03-20 21:34:59
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:04
The network socket is connected. | 2014-03-20 21:35:04
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:04
TWS server version: 67 | 2014-03-20 21:35:04
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:04
Disconnected from IB. | 2014-03-20 21:35:04
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:04
Starting TWS auto-login thread. | 2014-03-20 21:35:08
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:09
The network socket is connected. | 2014-03-20 21:35:09
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:09
TWS server version: 67 | 2014-03-20 21:35:09
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:09
Disconnected from IB. | 2014-03-20 21:35:09
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:09
TWS auto-login thread ending. | 2014-03-20 21:35:10
Starting TWS auto-login thread. | 2014-03-20 21:35:12
TWS auto-login thread ending. | 2014-03-20 21:35:13
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:14
The network socket is connected. | 2014-03-20 21:35:14
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:14
TWS server version: 67 | 2014-03-20 21:35:14
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:14
Disconnected from IB. | 2014-03-20 21:35:14
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:14
Starting TWS auto-login thread. | 2014-03-20 21:35:16
TWS auto-login thread ending. | 2014-03-20 21:35:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:19
The network socket is connected. | 2014-03-20 21:35:19
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:19
TWS server version: 67 | 2014-03-20 21:35:19
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:19
Disconnected from IB. | 2014-03-20 21:35:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:19
Starting TWS auto-login thread. | 2014-03-20 21:35:20
TWS auto-login thread ending. | 2014-03-20 21:35:21
Starting TWS auto-login thread. | 2014-03-20 21:35:24
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:24
The network socket is connected. | 2014-03-20 21:35:24
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:24
TWS server version: 67 | 2014-03-20 21:35:24
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:24
Disconnected from IB. | 2014-03-20 21:35:24
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:24
TWS auto-login thread ending. | 2014-03-20 21:35:25
Starting TWS auto-login thread. | 2014-03-20 21:35:28
TWS auto-login thread ending. | 2014-03-20 21:35:29
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:29
The network socket is connected. | 2014-03-20 21:35:29
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:29
TWS server version: 67 | 2014-03-20 21:35:29
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:29
Disconnected from IB. | 2014-03-20 21:35:29
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:29
Starting TWS auto-login thread. | 2014-03-20 21:35:32
TWS auto-login thread ending. | 2014-03-20 21:35:33
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:34
The network socket is connected. | 2014-03-20 21:35:34
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:34
TWS server version: 67 | 2014-03-20 21:35:34
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:34
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:34
Disconnected from IB. | 2014-03-20 21:35:34
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:34
Starting TWS auto-login thread. | 2014-03-20 21:35:36
TWS auto-login thread ending. | 2014-03-20 21:35:37
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:39
The network socket is connected. | 2014-03-20 21:35:39
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:39
TWS server version: 67 | 2014-03-20 21:35:39
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:39
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:39
Disconnected from IB. | 2014-03-20 21:35:39
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:39
Starting TWS auto-login thread. | 2014-03-20 21:35:40
TWS auto-login thread ending. | 2014-03-20 21:35:41
Starting TWS auto-login thread. | 2014-03-20 21:35:44
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:44
The network socket is connected. | 2014-03-20 21:35:44
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:44
TWS server version: 67 | 2014-03-20 21:35:44
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:44
Disconnected from IB. | 2014-03-20 21:35:44
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:44
TWS auto-login thread ending. | 2014-03-20 21:35:45
Starting TWS auto-login thread. | 2014-03-20 21:35:48
TWS auto-login thread ending. | 2014-03-20 21:35:49
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:49
The network socket is connected. | 2014-03-20 21:35:49
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:49
TWS server version: 67 | 2014-03-20 21:35:49
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:49
Disconnected from IB. | 2014-03-20 21:35:49
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:49
Starting TWS auto-login thread. | 2014-03-20 21:35:52
TWS auto-login thread ending. | 2014-03-20 21:35:53
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:54
The network socket is connected. | 2014-03-20 21:35:54
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:54
TWS server version: 67 | 2014-03-20 21:35:54
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:54
Disconnected from IB. | 2014-03-20 21:35:54
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:54
Starting TWS auto-login thread. | 2014-03-20 21:35:56
TWS auto-login thread ending. | 2014-03-20 21:35:57
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:35:59
The network socket is connected. | 2014-03-20 21:35:59
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:35:59
TWS server version: 67 | 2014-03-20 21:35:59
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:35:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:35:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:35:59
Disconnected from IB. | 2014-03-20 21:35:59
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:35:59
Starting TWS auto-login thread. | 2014-03-20 21:36:00
TWS auto-login thread ending. | 2014-03-20 21:36:01
Starting TWS auto-login thread. | 2014-03-20 21:36:04
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:04
The network socket is connected. | 2014-03-20 21:36:04
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:04
TWS server version: 67 | 2014-03-20 21:36:04
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:04
Disconnected from IB. | 2014-03-20 21:36:04
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:04
TWS auto-login thread ending. | 2014-03-20 21:36:05
Starting TWS auto-login thread. | 2014-03-20 21:36:08
TWS auto-login thread ending. | 2014-03-20 21:36:09
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:09
The network socket is connected. | 2014-03-20 21:36:09
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:09
TWS server version: 67 | 2014-03-20 21:36:09
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:09
Disconnected from IB. | 2014-03-20 21:36:09
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:09
Starting TWS auto-login thread. | 2014-03-20 21:36:12
TWS auto-login thread ending. | 2014-03-20 21:36:13
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:14
The network socket is connected. | 2014-03-20 21:36:14
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:14
TWS server version: 67 | 2014-03-20 21:36:14
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:14
Disconnected from IB. | 2014-03-20 21:36:14
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:14
Starting TWS auto-login thread. | 2014-03-20 21:36:16
TWS auto-login thread ending. | 2014-03-20 21:36:17
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:19
The network socket is connected. | 2014-03-20 21:36:19
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:19
TWS server version: 67 | 2014-03-20 21:36:19
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:19
Disconnected from IB. | 2014-03-20 21:36:19
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:19
Starting TWS auto-login thread. | 2014-03-20 21:36:20
TWS auto-login thread ending. | 2014-03-20 21:36:21
Starting TWS auto-login thread. | 2014-03-20 21:36:24
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:24
The network socket is connected. | 2014-03-20 21:36:24
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:24
TWS server version: 67 | 2014-03-20 21:36:24
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:24
Disconnected from IB. | 2014-03-20 21:36:25
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:25
TWS auto-login thread ending. | 2014-03-20 21:36:25
Starting TWS auto-login thread. | 2014-03-20 21:36:28
TWS auto-login thread ending. | 2014-03-20 21:36:29
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:30
The network socket is connected. | 2014-03-20 21:36:30
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:30
TWS server version: 67 | 2014-03-20 21:36:30
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:30
Disconnected from IB. | 2014-03-20 21:36:30
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:30
Starting TWS auto-login thread. | 2014-03-20 21:36:32
TWS auto-login thread ending. | 2014-03-20 21:36:33
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:35
The network socket is connected. | 2014-03-20 21:36:35
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:35
TWS server version: 67 | 2014-03-20 21:36:35
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:35
Disconnected from IB. | 2014-03-20 21:36:35
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:35
Starting TWS auto-login thread. | 2014-03-20 21:36:36
TWS auto-login thread ending. | 2014-03-20 21:36:37
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:40
The network socket is connected. | 2014-03-20 21:36:40
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:40
TWS server version: 67 | 2014-03-20 21:36:40
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:40
Disconnected from IB. | 2014-03-20 21:36:40
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:40
Starting TWS auto-login thread. | 2014-03-20 21:36:40
TWS auto-login thread ending. | 2014-03-20 21:36:41
Starting TWS auto-login thread. | 2014-03-20 21:36:44
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:45
The network socket is connected. | 2014-03-20 21:36:45
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:45
TWS server version: 67 | 2014-03-20 21:36:45
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:45
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:45
Disconnected from IB. | 2014-03-20 21:36:45
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:45
TWS auto-login thread ending. | 2014-03-20 21:36:45
Starting TWS auto-login thread. | 2014-03-20 21:36:48
TWS auto-login thread ending. | 2014-03-20 21:36:49
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:50
The network socket is connected. | 2014-03-20 21:36:50
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:50
TWS server version: 67 | 2014-03-20 21:36:50
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:50
Disconnected from IB. | 2014-03-20 21:36:50
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:50
Starting TWS auto-login thread. | 2014-03-20 21:36:52
TWS auto-login thread ending. | 2014-03-20 21:36:53
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-20 21:36:55
The network socket is connected. | 2014-03-20 21:36:55
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-03-20 21:36:55
TWS server version: 67 | 2014-03-20 21:36:55
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68 | 2014-03-20 21:36:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-20 21:36:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-20 21:36:55
Disconnected from IB. | 2014-03-20 21:36:55
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-20 21:36:55
Starting TWS auto-login thread. | 2014-03-20 21:36:56
TWS auto-login thread ending. | 2014-03-20 21:36:57
File >> Disconnect selected. | 2014-03-20 21:36:58
Disconnected from IB. | 2014-03-20 21:36:58
Current selected Data/Trading service: Interactive Brokers | 2014-03-20 21:46:11
The above has been sent to support. | 2014-03-20 21:51:16
Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2014-03-20 21:51:17
[2014-03-21 03:23:03]
Yes. We can help with this. There is actually a newer version of IB Trader Workstation which is available and it can be downloaded with this link:
https://download2.interactivebrokers.com/download/tws40_install_latest.exe
