Date/Time: Thu, 02 May 2024 14:28:30 +0000
developing daily high/low
View Count: 1193
[2014-03-20 18:37:01] |
User63439 - Posts: 83 |
hi there, still waiting for the 1000 volume chart cl may contract (time zone brussels, session time from 00:00:00 - 23:59:59) i wannted to ask if its possible with sierra to draw like a developing daily high/low (see picture, green line). thanks in advance |
developing_high_low.png / V - Attached On 2014-03-20 18:36:35 UTC - Size: 60.36 KB - 396 views |
[2014-03-20 23:34:49] |
vegasfoster - Posts: 444 |
The study is called Daily OHLC.
[2014-03-21 05:07:22] |
Sawtooth - Posts: 3990 |
Use the Daily OHLC study, set the Graph High and Low Historically to Yes, set the Reference Days Back to 0, set Draw Styles: Open to Ignore High to Line Low to Line Close to Ignore |
[2014-03-21 09:12:04] |
Here is the reference for the Daily OHLC study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s137 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-21 10:22:23] |
bada bing, thanks a lot!
