Date/Time: Sun, 08 Nov 2026 00:35:01 +0000
start and end time for candles
View Count: 1625
| [2021-08-12 23:17:02] |
| Paolo Padoin - Posts: 1 |
the 30 min candle is starting at 6:15 and goes to 6:45. i would like it to start at 6:30 and go to 7:00 I can not find how to configure it thx |
| [2021-08-13 06:01:20] |
| User907968 - Posts: 885 |
Check your chart session times - Chart Session Times: Session Times
| [2021-08-19 19:38:04] |
Yes refer to this page: Chart Session Times: Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
