Date/Time: Mon, 06 May 2024 09:27:13 +0000
What to do to fix OEC data issue
View Count: 1078
[2014-03-20 17:48:39] |
GCAdmin - Posts: 35 |
It looks like there is a fix for the OEC issue, but I have not been able to figure out what all the proper steps are to get my futures charts especially by 6EM4 Chart to show the correct data still. Can you please explain what steps I need to take to get this chart running again? I have updated to the most recent SC by going to HELP>> Download current version. What is the next step after that? Thank you so much for your help.
[2014-03-20 23:00:50] |
NumbersBars - Posts: 141 |
If you are talking about currency futures data issue. I thought it was at the sticky thread , top of this forum OEC Currency Futures Data It works for me. hope it helps. |
[2014-03-20 23:54:17] |
Yes. Refer to this thread: OEC Currency Futures Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
