Date/Time: Fri, 06 Nov 2026 01:10:37 +0000
Rithmic europe connection
View Count: 1376
[2021-08-08 07:47:53]
User401463 - Posts: 3
Hello!
How do I connect to rithmic european servers? Papertrading and funding companies server options.
Will the plugin mode to rithmic be available in the forseeable future?
Is continous contracts with rithmic coming back?
Regards,
A
[2021-08-09 06:22:14]
Not through Rithmic data. You need to use the Denali Exchange Data Feed for data:
Rithmic set up instructions are here:
Rithmic Trading Platform Service
We do not know what this means. Rithmic is supported and the documentation is here:
Date Time Of Last Edit: 2021-08-09 06:23:16
[2021-08-12 17:21:47]
OK. Denali for continous.
There is nothing about server locations in those instructions.
I attached a picture with the rithmic connections that I cannot find in sierra. Europe and frankfurt. Is it possible to get them?
There is a significant difference in latency.
There is also the plugin mode in yellow text. So that you can have many programs on one connection. Will that be supported in the future?
imageRithmic europe.PNG / V - Attached On 2021-08-12 17:15:45 UTC - Size: 78.9 KB - 373 views
[2021-08-13 18:14:16]
We do not have answers to your questions. These are things controlled by Rithmic. We have asked Rithmic to add the Frankfurt connection. And we will see what they do in regards to the plug-in mode.
[2021-08-13 18:19:17]
Thank you!
