Date/Time: Thu, 09 May 2024 01:02:22 +0000
Trade Activity Log
View Count: 1107
[2014-03-20 14:40:12] |
User52866 - Posts: 13 |
Dear All, I am not able to run trade activity log: 1) not able to select Sim in the window itself, always switches to Non-simulated option 2) when some data are filtered then it states "Connected to server" ano no other details. 3) Simulation fills source - selected "All fills" Thanks a lot |
[2014-03-20 15:25:09] |
If you want to display Trade activity for simulated trading, then you need to select in the list of symbols at the top of the Trade Activity Log the particular symbol that has [Sim] in front of it. Refer to the steps here: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ViewingHistoricalTA Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
