Date/Time: Sat, 04 May 2024 16:39:44 +0000
Sierra data not working
View Count: 1006
[2014-03-20 12:12:37] |
PeteRice - Posts: 3 |
Hi, At 12.01 GMT, the sierra chart data feed on indices has stopped working. Any ideas as to reason? Thanks |
[2014-03-20 15:06:01] |
What is the symbol you are referring to?
[2014-03-20 15:11:25] |
At that specific time and for the following 20 minutes, the following symbols had no data - GER30, FRA40, UK100, EUSTX50 & US30...there masy have been more, but they were the ones I had open.
[2014-03-20 15:22:01] |
We can confirm there was an outage from about 12:02 to 12:22 UTC time for the symbols. This was an outage from FXCM. We cannot restore the missing data.
