Date/Time: Fri, 03 May 2024 10:36:19 +0000
original entry prices
View Count: 990
[2014-03-20 12:07:35] |
AKR - Posts: 523 |
Is there a way to not only see the average entry price in a DOM, but also the single prices to which orders were entered? thx!! |
[2014-03-20 19:12:08] |
No. Maybe the Trades tab of the Trade Activity Log will be helpful to you: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-20 19:12:24
[2014-03-20 19:18:28] |
AKR - Posts: 523 |
no. that does not help. would be a good feature. because when you scale in then you would like to know at which level you can scale out again with parts of your positions. you dont just sacale in and then scale out above (when long) the average but you might also scale out at level XXX which is above scale in.... thx anyway |
