Date/Time: Sat, 04 May 2024 20:56:34 +0000
files to open on startup feature not working
View Count: 2215
[2013-04-22 21:10:48] |
Jim - Posts: 31 |
Im trying to add my chart books to open on start-up but when im starting up up software I get "chartbook file not found" in message box. The software has no problem locating the chartbooks when opening one by one. Thanks for your help. |
[2013-04-22 21:12:47] |
You need to make sure these Chartbooks are located in the Sierra Chart Data Files Folder. Otherwise, you will get that error.
[2013-04-22 22:50:11] |
Jim - Posts: 31 |
That worked. Thank you.
