Date/Time: Wed, 25 Nov 2026 12:49:15 +0000
Orderflow problems
View Count: 751
| [2021-08-04 13:08:07] |
| User967852 - Posts: 26 |
My order flow seems to be broken as my footprint/cd indicate strong buying on down moves and strong selling on up moves consistently through any market conditions. I am on a rithmic data feed if that helps. Could you tell me how to fix this?
| [2021-08-04 15:16:28] |
| John - SC Support - Posts: 48648 |
It could just be that what you are seeing is the way it is. But, we do recommend using the Denali Exchange Data Feed in order to ensure that you have the best data available. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
