Date/Time: Wed, 25 Nov 2026 07:43:47 +0000
Long low wick on candlestick is not supported by price data
View Count: 928
| [2021-08-03 07:02:57] |
| User467025 - Posts: 4 |
Looking at VIX oct contract, daily. http://www.sierrachart.com/image.php?Image=1627973821561.png Today the candlestick shows a low of 22.40, but in reality it is 23.05 as shown in 15 min chart http://www.sierrachart.com/image.php?Image=1627973943863.png The data from the VIX...dly file also seems correct, yesterday and todays lines here: 2021/08/02, 22.79999924, 23.50000000, 22.39999962, 23.45000076, 4912, 2289 2021/08/03, 23.29999924, 23.29999924, 23.04999924, 23.14999962, 213, 108 |
| [2021-08-03 14:42:38] |
| John - SC Support - Posts: 48648 |
Refer to the following: Historical Chart Prices: 12.2 - Comparing High And Low In a 24 Hour Historical Daily Chart To an Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-03 15:48:19] |
If you look at the .dly data I posted, the low of the day was 23.04. So why is the wick going all the way down to 22.40? It is supposed to plot the data in the .dly file?
| [2021-08-03 16:52:08] |
What is the name of the daily file from which you extracted those lines?
| [2021-08-03 17:00:04] |
VIX-20211020-CFE-USD-1000.dly
| [2021-08-03 18:51:01] |
| Sierra_Chart Engineering - Posts: 25479 |
Refer to: Historical Chart Prices: 12.4 - Origin of Data in a Historical Chart For the proper volatility index from the CFE data, you need to use the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-03 20:49:02] |
I can not trust a tool which not correctly plots the data present in a file. I must trade the market data as I see them from IB. Consequently I have to stop using Sierra, although I like the nice charts and flexibilty |
