Date/Time: Sun, 05 May 2024 05:43:32 +0000
Chart Settings
View Count: 1044
[2014-03-20 01:12:03] |
User41116 - Posts: 10 |
Hi, I have a session times setting for a particular chart starting at 09.50 per the screenshot file uploaded. Despite this setting, the first TPO 'A' for the session starts at 10.00 which can lead to different signals. See link http://www.sierrachart.com/image.php?l=1395277450693.png Can you please advise what might be amiss? Thanks Chris |
Attachment Deleted. Settings.PNG / V - Attached On 2014-03-20 01:11:25 UTC - Size: 51.63 KB - 337 views |
[2014-03-20 01:51:04] |
If you open another chart for that symbol, do you see any data from 9:50 to 9:59?
[2014-03-20 06:29:09] |
If you mean duplicate chart - no data from 9.50-9.59 |
[2014-03-20 06:55:07] |
We have to check the code to confirm, but what it looks like is that the starting time shown for the TPO profile will show the first time encountered since the specified session starting time.
[2014-03-20 07:32:15] |
In case this helps - I referred a contact of mine who downloaded SC. He uploaded my chartbook, which included the chart settings and starting times. His profile commenced with data at 9.50. If he changed his setting to 10.00 the profile looked the same as mine. I updated SC to the newest version, but this did not fix the discrepancy. My settings are set at 9.50 but appears to be set at 10.00. Thanks |
[2014-03-20 08:19:15] |
Re-download the last two days of data in the chart, following the instructions in help topic 7.1: http://www.sierrachart.com/index.php?l=doc/helpdetails7.html Reset the TPO chart with Chart >> Reset TPO Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
