Date/Time: Wed, 18 Nov 2026 07:18:51 +0000
Adjusting Horizontal Line Study by dragging it on the Chart
View Count: 1790
[2021-07-31 22:28:35]
Midas003 - Posts: 9
I normally draw several horizontal lines on my charts using the Horizontal Line Drawing tool. However, i wanted to create an alert for when certain candle patterns occur around this Horizontal lines, the only way I am aware that this can be done is by drawing these lines using the Horizontal line study. Now, my issue is that I draw numerous lines on my chart and sometimes need to quickly adjust the lines on the chart as they are based on levels from different Timeframes.
My question is: Is there a way I can manually adjust these lines on my chart that were placed using the Horizontal line study by simply dragging it around on the chart??? (u know the same way i can drag the lines around if done with the horizontal line drawing tool) rather than having to go into to the study settings as it is a hassle & time consuming having to manually change the price for each line in order to adjust the lines on the chart
[2021-08-02 08:46:24]
No this is not supported but you can set alerts on the Horizontal Line drawings:
Chart Drawing Tools: Chart Drawing Alerts
You could also use the Spreadsheet Study:
Overview of Spreadsheet Studies
And then edit the values in Sheet Cells.
Date Time Of Last Edit: 2021-08-02 08:46:41
