Date/Time: Mon, 16 Nov 2026 11:35:55 +0000
Problem to data .....late
View Count: 821
| [2021-07-30 16:31:51] |
| User170214 - Posts: 6 |
Why do I have the data behind NINJA CQG ? Tanks https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=53269 |
| [2021-07-30 16:32:22] |
To continue to receive real-time CME data through the Denali Exchange Data Feed when using the lower-priced CME exchange fees which are enabled on your account, requires that you connect Sierra Chart to your live trading account at least once a month. For instructions, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Sierra Chart Support |
| [2021-07-30 16:53:27] |
Sorry but I don't have a trading account on SIERRA I use SIERRA at the level of analysis and that's it ..... So you tell me that I need to have a TRADING account? I was fine with AMP FUTURES and you have changed the cards? Can I use SIERRASHARTS with AMP FUTURES and DANALI as a data source? Why I'm going back to AMPFUTURES ..... Thanks Claudio Sala |
| [2021-07-30 17:29:33] |
For more information about this, refer to this section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Can I use SIERRASHARTS with AMP FUTURES and DANALI as a data source? Yes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-30 17:29:54
