Date/Time: Wed, 18 Nov 2026 07:18:47 +0000
Left side scale
View Count: 1502
[2021-07-29 17:45:07]
User837393 - Posts: 161
I'm using the left side scale as part of my chart.
The price lader is there, but there is no price box.
How can I activate/see the price box on the left side scale ?
Best regards.
[2021-07-29 18:28:29]
To have the Price Box displayed in the Left Side Scale, you need to add the Current Price Line study to the chart and turn on the Value Label and set it to display in the Left Side Scale. Refer to the following:
Chart Studies: Subgraphs Tab >> Name and Value Labels
You can then set the Subgraph to Hidden to not have the line show in the chart. Refer to the following:
Chart Studies: Hidden (ACSIL: DRAWSTYLE_HIDDEN)
[2021-07-29 18:47:06]
The issue is that when you set it to Hidden (or ignore) not only the line disapear, but the price box as well.
[2021-07-29 18:57:20]
Sorry, you are correct. You need to set the Draw Style to Subgraph Name and Value Labels Only.
