Date/Time: Tue, 29 Sep 2026 14:06:16 +0000
Starting up
View Count: 1001
[2021-07-29 16:23:16]
User279510 - Posts: 21
Good morning,
I am coming in with the OrderFlowLabs group. I am currently on a trial. I have an account with Edgeclear, which clears through Phillips. I am using Rithmic, but that does not load historical data anymore on SC. I can switch to TT or CQG at Edgeclear. It appears I need to set up SC with Denali, clearing thru TT at Phillips. I am currently paying CME data fees thru Edgeclear.
I think I should sign up for Advanced with Denali, $46 month. Is there something else I need to pay, besides the .10 per turn trade fee?
Follow up. Speaking with my broker, he also has clients that run SC with Denali and execute with Rithmic. I am neutral on this, over TT. Just trying to get up and running. Thanks for your time.
[2021-07-29 16:44:49]
John - SC Support - Posts: 48048
We do recommend using the Sierra Chart Order Routing Service, as we feel that it offers benefits above other services. Refer to the information here:
https://www.sierrachat.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php
Or you can use Rithmic for your order routing. It is really up to you.
But, in either case, you will need to use the Denali Exchange Data Feed in order to get the data you need. In addition to the cost of the package, you will also have the Exchange Fee(s) that you will need to pay.
For setup instructions for the CME Group data with the Denali Exchange Data Feed, refer to the following:
If you need EUREX or CFE data, those instructions are on that same page.
