Date/Time: Mon, 29 Apr 2024 01:43:46 +0000
Accessing & obtaining S&P Futures Data
View Count: 1039
[2014-03-19 19:39:25] |
User18310 - Posts: 1 |
I have Sierra chart package 3 and trade Es CME front month contract which now is ES-201406-CME. QUESTION: I currently have the ability to go back right now to the (exp.)December contract 2013 and research any time frame 1,3,5,15,30... on dec 2013 expired contract, which I believe will be removed from available symbols in a few days. I need to continue the ability to access the ES-201312-CME contract IN ALL TIME FRAMES for the next few weeks.(I'm using Instance: "TT Fix" in main settings.) Can,how,what and where do I need to go/do to continue to access dec 2013 contract in all time frames. Please advise. Tks in advance for your consideration and appreciate the help.
[2014-03-21 06:30:07] |
You will always have access to this or older symbols, even if it is not listed in File >> Find Symbol. Refer to help topic 42.2 here: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
