Date/Time: Mon, 29 Apr 2024 18:02:19 +0000
price and connect ibkr
View Count: 438
[2021-07-28 18:03:43] |
jpbeaudoin - Posts: 2 |
i sorry for my english...i speak french if i understood correctly ... you can provide realtime data in the ibkr platform ... (interactive brookers = ibkr) can i read them from ibkr and pass my trades through ibkr? and I can surely use the ibkr screener from your data i can see the bid and ask in option and in the level 2 ? realtime i can see times and sales ? realtime i can see delta, vega, theta in option realtime ? I need the US and I also use the options with strategy ... I await your answer .. if this is conclusive .. I will remind you on other questions before moving forward with you now i test your sierra chart free 15days with interractive brokers simulate check picture .. i have not same time .. and error code ? regards, Date Time Of Last Edit: 2021-07-28 20:12:44
connect ibkr simulate.JPG / V - Attached On 2021-07-28 20:12:24 UTC - Size: 375.92 KB - 147 views |
[2021-07-29 14:28:15] |
John - SC Support - Posts: 31182 |
You can get your data from either IBKR or from us. If you are interested in the U.S. Stocks and you need to have the Level 2 Market Depth data, then you would need to get your data from IBKR right now, as we do not have the level 2 data with our data feed at the moment. We do not have the Greeks (Delta, Theta, Vega) available within Sierra Chart. You would need to get that information elsewhere. Otherwise, the other information you are asking about is available. The items you show in the image are not errors, they are just informational notes about the status of the connection. Everything is showing correctly and is not a problem. ------------ We do want to point out that we are working on a new interface for the U.S. Stock data that will include the Level 2 data. This should be available in a few months. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-29 15:13:04] |
thanks for your return for your new interface for American stocks .. with level 2 ... this will meet all my needs if I understand correctly ... and will work with ibkr? if the price is not too expensive I would be interested ... available before 2021 .. . ??? |
[2021-07-29 16:11:50] |
Yes, our new U.S. Stock interface will include the Level 2 data and will meet your needs, except for the Greeks, as that will not change. The new U.S. Stock interface will work with IBKR. We do not have a price for this exchange option yet. We hope to have it completed before the end of 2021, but various things happen and we can not give a commitment date. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
