Date/Time: Mon, 29 Apr 2024 07:39:40 +0000
Trades on Chart sometimes covered with 0s
View Count: 385
[2021-07-28 14:15:54] |
ycomp - Posts: 274 |
sometimes I hit a key accidentally on my keyboard, I think that is how it is activated.. and afterwards until I restart Sierra Chart, whenever I "Show Order Fills" it will draw 0s (or Os?) all along the trade lines. What is this and how do I disable it? |
[2021-07-28 14:25:34] |
When you see this, post an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-28 14:25:43
[2021-08-16 19:35:32] |
attached you can see the 0s.. what are they and how can I get rid of them?
Clipboard01.png / V - Attached On 2021-08-16 19:34:49 UTC - Size: 21.61 KB - 125 views |
[2021-08-16 19:58:30] |
What is happening is you are selecting one of the Tool Edit Modes (such as Move Drawing, or Adjust Drawing, etc.) and the system is displaying the information for which drawing you want to select. It is showing the Order Fill Connecting lines as an option to select by choosing the 0. We will look into why the order fill connecting lines are included when selecting a drawing. In the meantime, when you have this happen, you just need to select a different Tool (such as Pointer) to get out of whatever selection mode you were in. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
