Date/Time: Fri, 03 May 2024 08:52:55 +0000
Color bar relative to its length
View Count: 522
[2021-07-28 08:14:46] |
AC109756 - Posts: 18 |
Hello, is it possible to put a bar of a certain color when it exceeds a number of ticks? Thanks |
[2021-07-28 15:25:15] |
Yes it can be done with this study: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-02 13:31:54] |
Thanks, I succeeded. L < H-TICKSIZE*8 Is it possible to make the bar also be a different color if the opening is above at the close and the opening is below at the close, in addition to the minimum length? For a color, I thought of =AND(L < H-TICKSIZE*8) =AND(C < O) or =AND(L < H-TICKSIZE*8) =AND(C > O) But it didn't work. Date Time Of Last Edit: 2021-09-02 18:06:28
[2021-09-02 14:26:10] |
Ackin - Posts: 1865 |
=AND(condition1,condition2)
[2021-09-02 18:06:10] |
Thank you very much Ackin ;)
